Multisim and Ultiboard
my circuit goes convergence error and it is not simulating
thank my friend!
have a nice
new year!!
Message 11 of 16
(2,322 Views)
Concerning number 5. I understand what you are saying and I would be inclined to believe that with 100% it would print the layout at exactly the same size as the board size. I will try this and take measurements to be sure with your board and get back to you and let you know for certain.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
Message 12 of 16
(2,309 Views)
ok!! thanks again!
have a nice day!!
Message 13 of 16
(2,305 Views)
hello again!!
i have another question.
about the seperation between digital and analog ground.
because you seperate them, i would like to know that if  im going to tranfer the circuit  to ultiboard, are they connected?
same to battery and vcc, are they also connected in ultiboard?
again i thank you!
have a nice day!
Message 14 of 16
(2,294 Views)
I can answer that real fast. No they are not connected on the board. You will have to run Net Bridges to them in order for them to hook up to your main incoming power. You have to do this on the power side and the ground side as well. It isn't that hard to do. Just goto PLACE>Net Bridge and select one from the database. It will ask you which 2 nets are to be connected. Just select the net for VCC and the net number for the analog power and place it on the board somewhere. When you autoroute, then it will automatically hook the net bridge on the board to the appropriate traces. Do the same thing for GND and Net.
The other option is to hook everything back to the way you had it to start with in Multisim before transfering it. It won't simulate properly under these conditions, but it would make the transfer more seemless. Whichever technique makes it easier for you is the one I would choose.
I hope this helps.
Have a Nice Day
Message 15 of 16
(2,279 Views)
Hi again!
actually i already transfer it to ultiboard! so i'll select option 1!!
thanks a lot!
regarding the size of the printing thingies, i did your advice to select 100%.
and it's a match!!
thanks again!! you really helped me!
have a nice day!!
Message 16 of 16
(2,269 Views)
