Multisim and Ultiboard
new component causing ultiboard to slow down and produce out of memory window
i just created a new footprint and component, but after putting it into multisim and forwarding it to ultiboard it causes ultiboard to run incredibly slowly, often resulting in it crashing or a "out of memory" window to appear. What could the problem be?
(6,236 Views)
....turns out it runs fine if i don't put any custom pad shapes on the footprint. Ultiboard seems to have a very hard time coping with custom pads...
(6,235 Views)
.....is there a way around this?
(6,232 Views)
Hi Pgo48,
What version of circuit design suite are you using ? It is worth checking the release notes for this version to see if this is a known issue and it could be fixed in future versions.
Thanks and Regards,
Thanks and Regards,
Supreeth.K
(6,203 Views)
Hi pgo48,
Have a look at this readme file which speaks about some issues related to custom pads being fixed in Version 10.1.1:
http://download.ni.com/support/softlib/Circuit_Design_Suite/10.1/10.1.1/readme_eng.html
It is worth trying this in the latest version of Circuit Design Suite.
Thanks and Regards,
Thanks and Regards,
Supreeth.K
(6,188 Views)
hi, my application version says 12.0.0 (12.0.592). I'll try and work round it - Id like to request more options for pad shapes on future ultiboards - rounded rectangle pads are very common!
(6,185 Views)
