Multisim and Ultiboard
no outputs during simulations
Hi all
So when I test my circuit using the multimeter tool, I see the correct output values being read. However, when I try to run a parameter sweep I get all zeros for my output values. When I run a Monte Carlo analysis, roughly 1.5% of the trials produce a valid output, while the rest of the trials fail to converge to a solution.
What could be happening here? It's not an overly complicated circuit I'm working with, but Multisim seems to have a much harder time with it than it has with past circuits I've worked with. I'm hoping that it's a setting in the program that I'm missing, but I could sure use some help/advice..
Thanks!
(3,130 Views)
Hi fodangle,
Is it possible for you to send us your circuit so we can take a look at what could be causing the issue.
Tayyab R,
National Instruments.
(3,112 Views)
