Multisim and Ultiboard
power 12v to 240v step up
hi i have the circuit below which uses the following components but i am haveing probs finding irf630-2 mosfets in multisim as well as pow dc to 240v.jpgpow dc to 240v.jpg
  • 12v Battery
  • MOSFET IRF 630 -2
  • 2N2222 Transistors
  • 2uf capacitors-2
  • Resistor
    • 680 ohm-2
    • 12k-2
12v-220v center tapped step up transformer
(3,795 Views)
Hi Seabar,
My name is Jaimie, I'm an applications engineer at National Instruments.
I am unsure what it is you're asking here?
Are you having trouble finding these components within multisim and therefore cannot implement the given example circuit?
Please correct me if I have interpreted the question incorrectly.
Jaimie
(3,758 Views)
hi jamie,i am haveing problems finding the proper mosfets and step up center tapped trans former,can u help
(3,754 Views)
As you're not able to find the components that you're looking for in multisim , I would suggest using the component Wizard, this allows you to create your own component. I have included a link to a site that gives a step-by-step guide on how to do this.
Creating a Custom Component in NI Multisim
http://www.ni.com/tutorial/3173/en/
I hope this is useful to you, let me know if you have any further questions.
Jaimie
(3,738 Views)
AOA i did not found any type of step up transformer can you plz help me?
(3,119 Views)
