Multisim and Ultiboard
shove
Can some one tell me if there is a shove wire mode in Multisim as there is in Ultiboard so that you can add a wire or move one without drawing over an existing one. Also how can you move a whole long straight wire  that has junctions along its length in one move? it used to work in earlier versions but now you have to move each segment separately.
Cheers
(3,881 Views)
I do not see a wire shove mode like Ultiboards trace shove mode nor do I recall Multisim ever having this feature. The only way to move a wire with junctions that I know of is to hold down the right mouse button and create a window around the wire to include all the junctions and then drag it where you want it.
Hope this helps
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,872 Views)
Sorry I was wrong about shove but in 5.7 the wiring was a lot easier and better. As I said you moved all sections together and didn't leave junctions behind when moving wires around
(3,866 Views)
