Multisim and Ultiboard
source errors in simulation
Why does this simulation produce wrong data?
I know there are many sources of unexpected results in a transient simulation, but here the sources don't even produce correct waveforms.  Look at Vpwm and Vac.  Those are just source outputs and go only to the input of a virtual comparator.  How can this be?
They are roughly correct between 600-800 usec, but just bizarre everywhere else.
If I remove the mosfet from the circuit the source waveforms then look a lot closer to what they should be.
Thanks.
(3,508 Views)
I placed an analog ground and connected it to the digital ground and that seems to have helped a lot of issues.
(3,507 Views)
This circuit should use only analog grounds because there do not seem to be any components which require a digital ground like gates etc.
Hope this helps.
Tayyab R,
National Instruments.
(3,499 Views)
