Multisim and Ultiboard
speeding up long transient simulations
I'm attempting to simulate a PWM amplifier with an H bridge output and feedback/ comparatros/etc.
The simulation is quite rough with default time steps, and if I try for a more accurate simulation with small time steps it takes a very long time.
One thing that would be nice it to stop the grapher continuously updating and wasting all that time.  Is there a way to do this?  I try to hide the window, but I don't see that it takes advantage of that and skips the graph update.
Another good thing to be able to do is to have the grapher update with a fixed, most recent data window width.  This would be way more useful that just packign millions of data points into the window which is re-drawn every 10 seconds or so.
Any ideas?
How can I configure the transient simulation to solve to more accuracy, without suffering the small timestep everywhere that it might not be needed so much?
Thanks.
(4,334 Views)
dbur,
Improving the grapher (including its peformance) is definitely on the radar.
Can you supply your circuit? I'll see if anything could be done.
Max
(4,333 Views)
Here is the file.  I'm simulating for 100msec with 1e-8 time steps.
(4,328 Views)
I think if I just close the grapher window it speeds up a bit, and at least doesn't stop for each graph update.
(4,325 Views)
so a few things...
You have floating (unused) components. I recommend that you delete them or move them to another design as these components actually get loaded into the simulator and get simulated.
I also recommend using the new COMPARATOR_IDEAL instead of the COMPARATOR_VIRTUAL (unless you need to model slew rate, sourcing/sinking limits, etc). Your running at 33kHz PWM or 30us period. You generally should not need a timestep smaller than 1us (I typically aim for TMAX that is 10-100 times smaller than PWM period). I am not sure what is "rough" in your observation.
Finally you can perhaps lossen some simulation tolerances (VNTOL=1e-4 ABTOL=1e-6) since you seem to be dealing with higher (than low-power IC) power levels.
Hope that helps.
Max
(4,322 Views)
I tried the settings you suggest.
At max timestep 300e-9 it simulates successfully, but the signals are all over the place, which should just not happen with this circuit.  (PWMsim1)
The same simulation with the only difference being min timestep = 30e-9  produced better waveforms (at least they were monotonic), but fails with an 'internal simulation error'. (PWMsim2b)
Maybe there is too much data for the grapher.
(4,316 Views)
