Multisim and Ultiboard
suggestion on High power rating MOSFET needed
NDS352AN and NDS352AP were used for switching as shown in the circuit. It works well for a bus-powered device. But for self-powered devices, it doesn't switch ON/OFF the device.
For ON condition, 5v is the output and for OFF condition also it gives 4.5v , thus the device is always ON.
Any suggestions?
Mathan
(7,552 Views)
switch the source and drain, looks like its flipped vertical
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(7,541 Views)
I agree with Chris, but there is more here. He is using Depletion Mode MOSFETs and these things conduct without a voltage present on the gate and require a reverse bias on the gate to turn them off. Since he is using a digital signal that will never occur. Therefore they will never give what he is looking for. I would suggest using Enhancement Mode MOSFETS as these act more like a normally open switch and probably would be better suited to this application.
I hope this helps.
Kittmaster's Component Database
Have a Nice Day
(7,532 Views)
agreed
Message Edited by kittmaster on 08-28-2008 10:43 PM
(7,529 Views)
/////lacy wrote: /////I would suggest using Enhancement Mode MOSFETS as these act more like a normally open switch and probably would be better suited to this application. Dear lacy, Thanks for the ideas. Also could you please suggest what Enhancement mode MOSFET shall i use? Thanks for your time, Mathan
(7,512 Views)
Accepted by Mathan
Only you can answer that, you need to know how much current will pass through it, how much power loss there will be based on Rds_on.  If your doing just simulation, anything will be "ok", but only you know what your app is and should research what your needs are......I like to run my max at 50% of the device capability........because I can......but typically avoid anything over 85%  of the max values..........good luck
(7,508 Views)
