Multisim and Ultiboard
suggestion scope offset fix
The scope's y offset(y pos) should be normalized to the y scale. This way you don't have to change the offset every time you change the scale. It's very annoying when you want to change the scale to have to change the position to match. It's as simple as multiplying the "offset" by the scale to get the true offset.
(3,091 Views)
Thank you for the suggestion.
Will definitely consider it.
Mahmoud W
(3,076 Views)
