12-06-2011 04:15 PM
The scope's y offset(y pos) should be normalized to the y scale. This way you don't have to change the offset every time you change the scale. It's very annoying when you want to change the scale to have to change the position to match. It's as simple as multiplying the "offset" by the scale to get the true offset.
12-09-2011 08:11 AM
Thank you for the suggestion.
Will definitely consider it.
Mahmoud W
