Multisim and Ultiboard
(ultiboard 11) Customizing Gerber file names extensions
Hi all,
I would like to know if it's possible to customize the gerber file names. For example: I would like the top file to be named "filename.TOP", or the bottom file "filename.BOT"   instead of "xyz.gbr" . Can it be configured or do I have to change the extensions manually ?
Thanks and best regards,
Jean
Jean
(3,847 Views)
Hello ?
Jean
(3,812 Views)
Is there a specific reason why you are trying to accomplish this?
Regards!
(3,810 Views)
Because we have a circuit board plotter (LPKF E44 model). The software controlling the machine uses specific file extensions. So I wanted to automate things a little bit instead of manually change the filenames. 🙂
Jean
(3,806 Views)
Accepted by topic author jcayer
Sorry, I do not see a way to automate this. There is an idea exchange website for Multisim and Ultiboard where you could suggest things like this:  https://forums.ni.com/t5/Multisim-and-Ultiboard-Idea/idb-p/multisimideas
(3,802 Views)
Thank you Joe I'll check it out !! 🙂
Jean
(3,796 Views)
