Multisim and Ultiboard
ultiboard problem
Whenever I create a new Ultiboard project, or create one from Multisim, I pick up some silkscreen legend and copper text objects from a previous project..
What is happening here, and how do I stop it happening?
(4,266 Views)
Hi David
I hope you're having a good day. I've been taking at look at this issue and it seems similar to something that has occured in the past. In this previous occurence, it turned out that the text 'belonged' to one of the components on the PCB. If you can locate the relevant component then you can right-click it and select Properties then Attributes to bring up the Attribute list. If you highlight the text attribute and select Remove from the buttons on the right-hand side then this should hopefully remove the text. If this doesn't work then could you possibly attach your project so that I can take a look at it and try to experiment until I can find another solution?
I hope this helps!
Kind Regards
Jeremy T
Technical Marketing
NI
(4,243 Views)
Accepted by david_c_partridge
I found out what the problem was - I'd saved some attributes of a PCB as "default" in PCB properties.
Opening a new project, deleting these attributes, and re-saving the "use as default" resolved the problem...
Dave
(4,241 Views)
Hi David
That's great, I'm glad to hear it's all working!
Best Regards
Jeremy T
Technical Marketing
NI
(4,238 Views)
