Multisim and Ultiboard
unable to find definition of model - what can I do?
When I try to run the simulation the Multisim 8.0 with a diode 1n4001 for example, it shows the follow error message:
unable to find definition of model - default assumed.
How can I solve this problem?
Thanks so much,
mcp.
(9,101 Views)
Hi MCP,
Can you attach the file so that we can look at your circuit?
Tien
Tien P.
(9,079 Views)
Hi Tien,
It´s a satisfaction talk to you. I attach the file and the error screen.
 When I try simulate the circuit the error mensage is: "unable to find definition of model - default assumed" .
When I enter in menu components, and click at model, the text area is empty. Another component that run fine this text area contain the specifications about the component.
MCP.
(9,067 Views)
Accepted by mpamponet
I think there is an issue with that component in the version you are using, I tried it in version 10 and it works.  You can download a trial version:
Tien
Tien P.
(9,030 Views)
