Multisim and Ultiboard
usb connector in ultiboard
Greeting to all i am new in the forum, nevertheless ive used multisim and ultiboard for a while now and recently ive got a question that i cant figure it out, ok the question is this:
Is there any pcb layout models of usb connectors in? if there are, what are theyre names? where are they? otherwise if there arent any, how can i create the layouts? does it takes a long time? I looked in the through hole and surface mounted components in the connectors tabs and didnt find anything. Im using ultiboard 10.0.1. Thank you in advance
(6,378 Views)
Check first exactly which package you are buying from your supplier, usually they have standard names, then try a search with that name in Ultiboard, otherwise, the datasheet of the part you are buying will likely have the dimensional drawings, this tutorial called Creating a Custom Component in NI Ultiboard  provides an example on how to create such footprint...
Nestor
(6,375 Views)
