09-18-2008 09:57 AM
This has been a bug in the past but I have not seen anything like it recently in the forums. I am using Multisim 10.1. I am running into a bug where the data I put into the User Field is not being stored. The data is present until I click OK to exit out of the component properties. If I go back into the user field to view the data, it is gone. This does not happen on all components and I run into this problem in the Master DB and the Corporate DB. Is there a way to get this to work reliably? This is a rather important feature to me as Multisim is still lacking a DB that can connect directly to Digi-Key or Mouser inventory to populate component data (inventory, price, part numbers....etc) much like ORCAD can now do. By the way, when will a feature like this be implemented?
Thanks!
Brian
09-18-2008 08:41 PM
