Multisim and Ultiboard
user field information lost
This has been a bug in the past but I have not seen anything like it recently in the forums. I am using Multisim 10.1. I am running into a bug where the data I put into the User Field is not being stored. The data is present until I click OK to exit out of the component properties. If I go back into the user field to view the data, it is gone. This does not happen on all components and I run into this problem in the Master DB and the Corporate DB. Is there a way to get this to work reliably? This is a rather important feature to me as Multisim is still lacking a DB that can connect directly to Digi-Key or Mouser inventory to populate component data (inventory, price, part numbers....etc) much like ORCAD can now do.  By the way, when will a feature like this be implemented?
Thanks!
Brian
(3,038 Views)
You can't save changes user fields or not to the master database.......the corp database path must be set for it to work properly, best bet is to use the user database, it works everytime.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,025 Views)
