 yalect
			yalect
			01-29-2016 01:13 PM
		02-01-2016
		10:38 AM
 - last edited on
		10-10-2025
		12:17 PM
 by
		 Content Cleaner
			Content Cleaner
Hello yalect,
If you have the SPICE model you can always create a new component using this documents as guide:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
In this document a list of all components of Multisim depending of the version:
http://www.ni.com/white-paper/5607/en/
If the component is not present in Multisim database version you will need to create it.
02-01-2016 01:56 PM
02-01-2016 03:06 PM
Hello Yalect,
I believe the tutorial is pretty straight foward and easy to follow. If you have any question about a part of it I will try to answer your questions, but you will have to create the component yourself. You will need the SPICE code and that is usually obtained from the component manufacturer
