Multisim and Ultiboard
vi characteristic - photovoltaic cell
Hi there,
i got multisim 10.1 and want to plot a VI characteristic with a 1-diode model of a photovoltaic cell
http://zone.ni.com/devzone/cda/tut/p/id/7230
i want to reduce the resistance of the potentiometer to generate the different measure points to plot my characteristic
i created the circuit, i also got 2 instruments to measure voltage and current. but i dont know how to plot those values into a graph
sorry for my bad english!
best regards
(4,837 Views)
The easiest is to drive the voltage across the pins and monitor the resulting current. Following this:
1. Connect DC voltage source across your PV cell's pins
2. Open DC Sweep analysis dialog
3. Set the appropriate voltage sweep range (0V to some value)
4. Set the output variable to be the current through the DC source
5. Hit Run
Max
(4,806 Views)
hi!
thank you very much! it works!
is there also a way to get the power characteristics? out of the U and I values?
(4,790 Views)
There is: just set up an expression I(test_voltage_source)*V(test_voltage_source)
You can set up this expression from within the analysis dialog - before you actually run the analysis, or by using the 'Add Trace' command within the grapher - after you've run the analysis.
Max
(4,750 Views)
