Multisim and Ultiboard
which is a dual 2-bit bistable transparent latch IC in multisim analog devices edition
I need an equivalent IC for CD74HC75, which is a dual 2-bit transparent latch IC, for a project simulation. Cant find it in the Multisim reference guide.
Any suggestions??
(6,051 Views)
Accepted by topic author emind
emind,
Hello, in the Multisim Analog Devices Evaluation Edition, you will find a D_Latch under the TIL family of parts (use 2 with EN tied together for a dual latch) that you can use for generic simulation purposes.   If you need a specific latch from a manufacturer or specific logic family that might be challenging (we have a few in the PRO version or you can add some external circuitry to the TIL part to mimic the behavior of a particular logic family).
The TIL parts (generic digital I/O) are located here:  Misc Digital (group) -> TIL -> D_LATCH.
I created a simple interactive circuit with a probe so you can observe the behavior to see if it will meet your simulation needs.
Pat Noonan
(6,044 Views)
Thank you sir... but again I am using multisim 10... can you repost the interactive circuit with multisim 10 components?
(6,036 Views)
The circuit I built in Multisim ADI edition v11 has some interactive digital I/O parts that are not part of v10.   Here is a screen shot of what I created, so you can duplicate it in v10.
For Multisim ADI edition v10 you can replace the interactive digital I/O parts with static voltage sources or with an interactive SPDT switch with logic high (5V) and gnd for the 2 sources to switch between...  (BASIC -> SWITCH -> SPDT).
The probe is found under: Indicators -> PROBE
Pat Noonan
(6,034 Views)
Thanks a lot, Sir. My project is working now! Smiley Happy
(6,029 Views)
