NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
存取問題?
請問一下,
我現在是利用DAQmx Read.vi讀取信號,
我們可以利用什麼原件將〝讀取到的訊號做儲存〞?
並可在打開觀察儲存到的訊號!
謝謝~
0 積分
1 條訊息(共 2 條)
3,634 檢視
In general, there is no fixed way to record the data acquired. Many cases, it depends on what is your read out format and what format is required/ requested by your customer(s).
Write/ Read To/From Spreadsheet File, Write/ Read Characters To/ From File, Write/ Read LabVIEW Measurement File etc can do the job...
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 積分
2 條訊息(共 2 條)
3,609 檢視
