NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Calibration Executive 3.5 Error Code -2147352571 occurred at 類型不相符。
已解決!
前往解決方案
您好,
執行Calibration Executive 3.5 最後都會出現ERROR CODE:
Calibration Executive Error Code -2147352571 occurred at 類型不相符。
Error -2147352571 occurred at 類型不相符。
in cex_ConvertUserField.vi->cex_ConvertUserFields.vi->cex_ConvertCalData30ToCalData.vi->cex_ConvertCalData30ToCalData.vi
at step Convert CalData30 to CalData.ProxyCaller
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-2147352571) or for its hexadecimal representation (0x80020005).
依照下面指示設定Regional Settings:
http://digital.ni.com/public.nsf/allkb/862567530005F09F862569740072221F
問題還是沒有解決.
移除再重灌也一樣.
安裝Calibration Executive 3.2就沒有這個問題.
請問是BUG嗎?
0 積分
1 條訊息(共 4 條)
6,687 檢視
I think you can forward this post to JaredRo. He might be the one that can answer if this is a bug.
Did you buy Calibration Executive 3.5 from NI Taiwan branch? If yes, you can call them directly for help.
0 積分
2 條訊息(共 4 條)
6,660 檢視
解決方案
接受者 PeterChang
此問題為Calibration Executive 3.5和WINXP語言相容性問題.
要使用英文(美國)語言.
解決方法:
1.安裝WINXP SP3更新.(已經更新SP3跳過此步驟)
http://www.microsoft.com/zh-tw/download/details.aspx?id=24
2.安裝WINXP MUI多國語言套件.
http://www.microsoft.com/en-us/download/details.aspx?id=22108
3.到 [控制台] -> [地區及語言選項] -> [進階] -> 非 UNICODE程式的語言- >英文(美國)
套用->確定->重新開機後
再執行Calibration Executive 3.5就OK.
0 積分
3 條訊息(共 4 條)
6,627 檢視
謝謝您
我們又學到一門學問
0 積分
4 條訊息(共 4 條)
6,617 檢視
