NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Can SCXI modules be connected to PC through SCXI-1600 via USB cable?
已解決!
前往解決方案
same as Subject.
Thank you
0 積分
1 條訊息(共 7 條)
7,597 檢視
yes.
PC >> USB port >> USB cable >> SCXI-1000+SCXI-1600
0 積分
2 條訊息(共 7 條)
7,586 檢視
Thank you
In fact, I have the following modules:
NI AT-MIO-16E-10
SCXI-1001
SCXI-1102
SCXI-1102B
SCXI-1303
SCXI-1160
SCXI-1324
Technician in my lab told me that NI AT-MIO-16E-10 is too old that new PCs do not have the corresponding connection plug. The PC has this plug is very old that does not support updated LabVIEW. Can I control the whole set of things by SCXI-1600?
PC >> USB port >> USB cable >> SCXI-1001 >> SCXI-1600 + (SCXI-1102+SCXI-1303) + (SCXI-1160+SCXI-1324)?
Also, I found that  (SCXI-1102+SCXI-1303) can also measure voltage input up to 10V. What is the difference between SCXI-1102 and SCXI-1102B?
0 積分
3 條訊息(共 7 條)
7,582 檢視
請問您的labview版本?
如果只是因為升級成新的PC,我會建議 PCI-6070E or SCXI-1600 取代 AT-MIO-16E-10
因為程式碼不需要改變。
如果您有其他考量, 例如 USB 攜帶方便,以下組態是OK的
至於1102, 1102b的差別,請看下面 ( 第二頁 )
http://www.ni.com/pdf/products/us/4scxisc278_ETC_196.pdf
0 積分
4 條訊息(共 7 條)
7,570 檢視
謝謝
現在連到AT-MIO-16E-10的PC是Windows 98, labview 6.0,
另外已有PC安裝了labview 8.6
如果不考慮攜帶方便及價錢,單看specification的話,
PCI-6070E或是SCXI-1600較好?
1102和1102b的差別方面, 應該只有filter frequency,
1102b有較高frequency, 200Hz,是不是應該比1102好?
0 積分
5 條訊息(共 7 條)
7,568 檢視
解決方案
接受者 Oscar Chan
spec.
pci-6070e > scxi-1600 ( 支援 traditional daq driver & daqmx driver )
以上推薦是考慮您有現存 labview 6.0 code 是由 traditional daq driver ( 舊 driver , since 1995 所組成。)
如果您打算重新寫 labview 8.6 code, 建議 pci-6251 & daqmx driver ( 新一代 driver, since 2002 )
另外, 測量溫度的雜訊環境各地不同, 有人需要的濾波器也不同,當然濾波器 cut-off frequency 越低, sample rate 越低
所以也沒有哪個比較好的問題.
如果以 sample rate 哪個可以比較高, 那麼建議 1102c>1102b>1102
6 條訊息(共 7 條)
7,565 檢視
謝謝你
已知道怎樣選擇了
0 積分
7 條訊息(共 7 條)
7,559 檢視
