NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
How to change gneration waveform with a HSDIO Board?
I would like to change sqare wave to triangle wave and sine wave. Can I change the waveform with a HSDIO board?
0 積分
1 條訊息(共 3 條)
4,604 檢視
Hi Aggssi,
The output waveform simply depends on the data written to HSDIO device.  The attached jpg file shows one way to generate sine(or square, triangle....) wave pattern.
Take a look at example file at this location: LabVIEW Window >> Help >> Find Examples >> Hardware Input and Output >>Modular Instruments >> NI-HSDIO >> Dynamic Generation >> Non-scripted >> Dynamic Generation of Multiple Waveforms.vi. You may have more ideas about the programming procedure to generate signal.
Ko-Wei
由 ko-wei 在 09-12-2007 02:37 AM 上編輯的訊息
由 ko-wei 在 09-12-2007 02:38 AM 上編輯的訊息
0 積分
2 條訊息(共 3 條)
4,595 檢視
Hello Aggssi.
No. You cannot.
HSDIO only generate square waveform.
You need Function Generator.
0 積分
3 條訊息(共 3 條)
4,586 檢視
