NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
LABVIEW NXT.vi Compile to LEGO?
已解決!
前往解決方案
NI工程師你好:
我使用
LEGO 8527
Labview 8.5
為何使用NXT.VI ,Compile不進NXT控制器裡呢?
        謝謝
圖片:
http://tw.myblog.yahoo.com/jw!mzZdj.6AHxST_PYNzqJ3O6QEFW.R/gallery?fid=2
0 積分
1 條訊息(共 3 條)
4,889 檢視
Installation Instructions
Before you install the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch, verify the computer meets the following conditions:
  • A compatible version of LabVIEW is installed.
  • The LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0 is installed.
  • LabVIEW is not running.
Windows
Complete the following steps to install the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch for Windows.
  1. Download the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT 1.0.1 Patch from ni.com/academic/mindstorms.
  2. Unzip the nxttoolkit101patch.zip file and open the directory that corresponds to the LabVIEW version installed on the computer.
  3. Copy the vi.lib directory you downloaded and paste this directory into the labview directory.
  4. In the copy warning dialog box, select Yes to All.
2 條訊息(共 3 條)
4,872 檢視
解決方案
由主題作者所接受 Compact RIO
Finding Examples
LabVIEW examples for the toolkit are located in the labview\examples\NXTToolkit folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
Known Issues
  • To run the toolkit efficiently, you must mass compile the toolkit VIs in the version of LabVIEW in which you install the toolkit. Complete the following steps to mass compile the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT.
    1. Launch the version of LabVIEW in which you installed the toolkit.
    2. Select Tools»Advanced»Mass Compile.
    3. Browse to the labVIEW\vi.lib\addons\NXTToolkit folder and select Current Directory (LabVIEW 8.x) or Curr Dir (LabVIEW 7.1).
    4. Select Mass Compile to begin the mass compile process.
3 條訊息(共 3 條)
4,869 檢視
