NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Line Scan Driver
I used Matorx SoL6MCL CamLink Card. And can I used It with NI acquisition Soft and How?
0 積分
1 條訊息(共 9 條)
7,022 檢視
Plz goto Matrox website to see if there's paid activeX library.
labview can access activex library. ( this experience from my friend )
0 積分
2 條訊息(共 9 條)
7,013 檢視
Thank you very much!
and I call The Matrox,they said The Matrox paid activeX library.So what should I do Next?
0 積分
3 條訊息(共 9 條)
7,009 檢視
Plz goto labview>>find examples>>activeX
or search activex+labview on ni.com
you can find many activex tutorials
0 積分
4 條訊息(共 9 條)
7,006 檢視
I used Vision with C#  ~any help Example?
Thanks~
0 積分
5 條訊息(共 9 條)
7,003 檢視
Regarding how to use activeX under C#, plz goto MSDN or contact Microsoft.
0 積分
6 條訊息(共 9 條)
6,998 檢視
I known how to use activeX under C#, but When I get the image how to Convert it to  Vision Member (VisionImage)?
I need to Convert the image to The NI-type VisionImage,and Process them.
For Example When I get the Image by activeX under C#,The Image type is Bitmap and how to convert it to VisionImage ?
Thanks for your help~~~
0 積分
7 條訊息(共 9 條)
6,992 檢視
try imaqArraytoImage
imaqArrayToImage
Usage
int imaqArrayToImage(Image* image, const void* array, int numCols, int numRows);
Purpose
Sets the pixels of an image to the values in a given array. This function resizes the image to the size of the source array.
0 積分
8 條訊息(共 9 條)
6,984 檢視
OK, I will try. Thank you very much.
0 積分
9 條訊息(共 9 條)
6,981 檢視
