NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Simulink如何與Labview連結
已解決!
前往解決方案
我已經有安裝Simulink Interface Toolkit 3.0.1的套件
也有照著Simulation Interface Toolkit Help 相關的說明
一步一步來.... 但是都無法成功...
不知是否有明確一點的步驟...
謝謝
0 積分
1 條訊息(共 45 條)
19,963 檢視
http://zone.ni.com/wv/app/doc/p/id/wv-352
上面有video
0 積分
2 條訊息(共 45 條)
19,954 檢視
謝謝...
小弟在請問一下...
DLL檔怎麼製作呢?!
0 積分
3 條訊息(共 45 條)
19,951 檢視
請解壓縮,他是.exe檔,video file
您必須安裝 VC++ 6.0,
透過 video file, 他是自動產生。
Message Edited by Fatty on 07-14-2009 10:38 PM
0 積分
4 條訊息(共 45 條)
19,946 檢視
謝謝你~
可以了^^
但是有一個疑問
我按照著(Simulation Interface Toolkit Help 相關的說明)裡面的步驟做
做簡單Sine Wave的控制
然而在simulink裡, 我必須要用一個Scope連到Sinewave那邊
不然Labview的chart wave會沒波形
Fatty大有什麼見解呢?!
Fatty大有做過(labview配合資料擷取卡來跟simulink做連結)相關的嗎?
0 積分
5 條訊息(共 45 條)
19,932 檢視
請問您的NI 配備是?
0 積分
6 條訊息(共 45 條)
19,928 檢視
是NI USB-6211
0 積分
7 條訊息(共 45 條)
19,926 檢視
您必須要有NI real-time 硬體。
開始>>程式集>>national instruments>>labview 8.x>>labview help>>索引>>Simulation Interface Toolkit, hardware device support and features
The LabVIEW Simulation Interface Toolkit supports running a simulation on the following types of National Instruments RT Series Hardware.
  • PXI/PCI
    • Any PXI-RT controller
  • FieldPoint
    • Any FieldPoint or Compact Fieldpoint controller with at least 32 MB of RAM. National Instruments recommends at least 64 MB of RAM. For targets with less than 32 MB of RAM, you should not install VISA if you want to use the SIT server in the driver VI.
  • CompactRIO
    • NI cRIO-9961
Refer to the KnowledgeBase for information about configuring hardware devices for use with the Simulation Interface Toolkit.
The following table shows the features available with each type of hardware.
Feature NI CAN Interfaces NI DAQ Devices NI FPGA Devices
Single-rate models Yes Yes Yes
Multi-rate models Yes Yes Yes
Single device configurable I/O Yes Yes Yes
Multiple device configurable I/O Yes Yes Yes
Mixed configurable I/O Yes Yes Yes
Custom FPGA VIs Yes1
Hardware timing Yes Yes
Analog I/O Yes2 Yes Yes
Digital I/O Yes2 Yes Yes
Pulse Width Modulation (PWM) I/O Yes2 Yes
Auto-detection of installed devices and I/O modules Yes Yes
1The Simulation Interface Toolkit ships with bitfiles and FPGA VIs for the following National Instruments FPGA devices:
  • NI PCI-7811R
  • NI PXI-7811R
  • NI PCI-7813R
  • NI PXI-7813R
  • NI PCI-7831R
  • NI PXI-7831R
  • NI PCI-7833R
  • NI PXI-7833R
  • NI cRIO-9103
You can use the LabVIEW FPGA Module to create custom FPGA VIs for other FPGA devices.
2The Simulation Interface Toolkit uses .dbc and/or .ncd files to determine the properties of a particular CAN channel.
0 積分
8 條訊息(共 45 條)
19,919 檢視
謝謝~~
現在大概就是說...
如果要用Labview配合資料擷取卡然後跟simulink做連結的話...
Simulink Interface Toolkit 只支援下列硬體嘛
  • NI PCI-7811R
  • NI PXI-7811R
  • NI PCI-7813R
  • NI PXI-7813R
  • NI PCI-7831R
  • NI PXI-7831R
  • NI PCI-7833R
  • NI PXI-7833R
  • NI cRIO-9103
很感謝您的幫忙^^
0 積分
9 條訊息(共 45 條)
19,911 檢視
抱歉,搞錯了。
http://zone.ni.com/devzone/cda/tut/p/id/4611
0 積分
10 條訊息(共 45 條)
19,909 檢視
