我已經有安裝Simulink Interface Toolkit 3.0.1的套件
也有照著Simulation Interface Toolkit Help 相關的說明
一步一步來.... 但是都無法成功...
不知是否有明確一點的步驟...
謝謝
已解決! 轉到解決方案。
在
07-14-2009
08:28 PM
- 上次修改時間
11-13-2024
09:59 AM
修改人
Content Cleaner
http://zone.ni.com/wv/app/doc/p/id/wv-352
上面有video
謝謝...
小弟在請問一下...
DLL檔怎麼製作呢?!
07-14-2009 10:36 PM - 已編輯 07-14-2009 10:38 PM
請解壓縮,他是.exe檔,video file
您必須安裝 VC++ 6.0,
透過 video file, 他是自動產生。
謝謝你~
可以了^^
但是有一個疑問
我按照著(Simulation Interface Toolkit Help 相關的說明)裡面的步驟做
做簡單Sine Wave的控制
然而在simulink裡, 我必須要用一個Scope連到Sinewave那邊
不然Labview的chart wave會沒波形
Fatty大有什麼見解呢?!
Fatty大有做過(labview配合資料擷取卡來跟simulink做連結)相關的嗎?
在 07-15-2009 03:34 AM
在
07-15-2009
03:52 AM
- 上次修改時間
11-13-2024
09:59 AM
修改人
Content Cleaner
您必須要有NI real-time 硬體。
開始>>程式集>>national instruments>>labview 8.x>>labview help>>索引>>Simulation Interface Toolkit, hardware device support and features
The LabVIEW Simulation Interface Toolkit supports running a simulation on the following types of National Instruments RT Series Hardware.
Refer to the KnowledgeBase for information about configuring hardware devices for use with the Simulation Interface Toolkit.
The following table shows the features available with each type of hardware.
Feature | NI CAN Interfaces | NI DAQ Devices | NI FPGA Devices |
Single-rate models | Yes | Yes | Yes |
Multi-rate models | Yes | Yes | Yes |
Single device configurable I/O | Yes | Yes | Yes |
Multiple device configurable I/O | Yes | Yes | Yes |
Mixed configurable I/O | Yes | Yes | Yes |
Custom FPGA VIs | – | – | Yes1 |
Hardware timing | – | Yes | Yes |
Analog I/O | Yes2 | Yes | Yes |
Digital I/O | Yes2 | Yes | Yes |
Pulse Width Modulation (PWM) I/O | Yes2 | – | Yes |
Auto-detection of installed devices and I/O modules | Yes | – | Yes |
1The Simulation Interface Toolkit ships with bitfiles and FPGA VIs for the following National Instruments FPGA devices:
You can use the LabVIEW FPGA Module to create custom FPGA VIs for other FPGA devices.
2The Simulation Interface Toolkit uses .dbc and/or .ncd files to determine the properties of a particular CAN channel.
謝謝~~
現在大概就是說...
如果要用Labview配合資料擷取卡然後跟simulink做連結的話...
Simulink Interface Toolkit 只支援下列硬體嘛
很感謝您的幫忙^^
在
07-15-2009
04:09 AM
- 上次修改時間
11-13-2024
10:16 AM
修改人
Content Cleaner
抱歉,搞錯了。
http://zone.ni.com/devzone/cda/tut/p/id/4611
