NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
.exe Build from LabWindow/CVI 7.1 run exception under RTE 8.0.1
Below is the source file  of test1.exe, which was built using LabWindow/CVI 7.1 environment, OS is Windows XP SP3
Due to some reason(install TestStand, or LabView, or ...), the Runtime  Engine  cvirte.dll, cvirt.dll (exists in c:\windows\system32\ )is 8.0.1
Executing this file, the GenericMessagePopup() will generate window's exception.  But if executing GenericMessagePopup() before LoadLibrary(), it will be ok.
By the way, "cp3245mt.dll" is Borland's DLL. If load other DLL, everything is OK.
Is there any suggestion to solve the conflict between NI and Borland? Thanks!
// test1.c  sourcefile
#include <windows.h>
#include <userint.h>
#include <stdio.h>
main()
// If execute the below line first. it will be ok.
//    GenericMessagePopup("Info", "Test","Yes","No",0,0,0,0,
//   VAL_GENERIC_POPUP_BTN1,VAL_GENERIC_POPUP_NO_CTRL,VAL_GENERIC_POPUP_BTN2);
   LoadLibrary("cp3245mt.dll");
   GenericMessagePopup("Info", "Test","Yes","No",0,0,0,0, VAL_GENERIC_POPUP_BTN1,VAL_GENERIC_POPUP_NO_CTRL,VAL_GENERIC_POPUP_BTN2);
0 積分
1 條訊息(共 1 條)
5,667 檢視
