Hello Circuit Designers,
NI tries to offer a complete design solution that helps engineers in many application areas from power electronics, to automotive, to clean energy to effectively simulate, prototype, and deploy their designs.
For motor control applications, the co-simulation feature with LabVIEW is a valuable addition on the simulation side. Engineers can model a complete system of analog circuitry and digital control code at the desktop level then easily deploy the code a target chip (such as FPGAs) and using Ultiboard quickly prototype the analog circuitry on PCB.
Enjoy,
Mahmoud W
