Suppose you have an OpAmp in the inverting configuration, like the one below.
Now the question is, what is the fastest and easiest way of getting the gain. (No mental math or calculators allowed here - you have to get Multisim to tell you the gain.)
I think the fastest way is using a reference probe. Probes in Multisim can reference other problems, and when they do, the default is to show the gain. To get the gain:
Start a simulation, and you have the probe will report the gain relative to Probe1.
