Hello Circuit Designers,
How do you use Multisim in your workplace? I recently came across an interesting whitepaper on using Multisim, LabVIEW and PXI to verify the design of flight and optical electronics for a satellite system that I wanted to share with the community.
Due to the harsh conditions, i.e. outer space, in which the satellite would be operating the accuracy of this design was of utmost importance. There were three stages to the design flow:
The final design prototype was connected to the PXI hardware. LabVIEW SignalExpress was used to acquire these real measurements. With real measurements being acquired through LabVIEW SignalExpress, and with the transfer of simulated data, we can correlate both sets of data. By viewing the differences between the data, the process of benchmarking and validating performance is easily done.
Campbell B
