When creating systems that include NI DAQ, NI Single-Board RIO, NI CompactRIO, or other hardware, circuit designers often need to develop signal conditioning boards, test fixtures, and other circuitry that are not available directly off the shelf. Multisim provides a large database of predefined, pin-accurate connector symbols that save hours when developing accessories for these hardware platforms. Rather than having to create a custom 50+ pin symbols and footprints, there is already a pre-populated library of such devices.
In Multisim 13.0 design templates has been added to accelerate prototype development and enable design reuse. The user defined templates for circuit schematics and PCB layouts help the user save a significant amount of time on the design they work on repeatedly with preconfigured devices, part placement, routing and board outlines.
