NI Circuit Design Community Discussions
Multisim and LabVIEW Variable Time-step Simulation Fills Big Gaps in Analog/Digital System Design
From your simulation results with MOSFET_DIODE_THERMAL model, the output voltage of H bridge is +-200V, all right? But the input DC voltage is 400V. They didn't match well. Is this the problem of MOSFET model? I tried to use ideal transistor-diode model and the output voltage of H bridge is +-200V as well.
Message 21 of 21
(2,226 Views)
