NI ELVIS
Elvis III Not Connecting in Measurements Live
When I try to connect the Elvis III in Measurements Live, it fails to connect and I am unable to use the SFP's.
I have a new Elvis III that is visible in MAX under "Devices and Interfaces".  It is not visible under "Remote Systems".  When powered on, my PC alerts me of the USB connection.  The the USB connection shows up in my device manager.  The Elvis is only identified as "USB Composite Device", "Portable Devices", and "Generic USB-EEM Network Adaptor".  The network adaptor device has the warning triangle on it.
The Elvis reflects a USB IP address but also states "ID: Not available."
All set-up steps were followed IAW the provided documents and the NI YouTube channel.  The Elvis Software Bundle was installed prior to connecting the Elvis to the laptop.  I have un/re installed several times.  The Elvis is registered under my NI account.
I am using Google Chrome to launch Measurements Live.
Any help is greatly appreciated.
Message 1 of 13
(8,987 Views)
The Elvis III is also identified as as Elvis III under "Portable Devices" in my Windows 10 Device Manager.
Message 2 of 13
(8,986 Views)
We're having the same issue, any assistance would be greatly appreciated.
Message 3 of 13
(8,688 Views)
add the Elvis url to your java security settings, fixed it for us
Message 4 of 13
(8,670 Views)
could you please explain how?
Message 5 of 13
(8,662 Views)
Yes, I have now the same problem. I can see Elvis in NI MAX under devices and also under Remote Systems (it si connected and running) but in MeasurementLive it is not possible to connect via USB. And for Wi-Fi I cannot set up the ID. Can you mentioned your solution, please?
Message 6 of 13
(8,602 Views)
I am also facing the same issues. Please reply me if anyone knows.
Message 7 of 13
(8,203 Views)
I found the simple solution, try it. The problem on my laptop was with the new version of Google Chrome which stop the support of live connection so I installed SlimJet Browser (https://www.slimjet.com/) and the Elvis and MeasurementLive work perfectly in it.
Hope it helps you also.
Message 8 of 13
(8,199 Views)
Me too. I'm also facing the same issue. Anyone! could you help me. Please!!!
Message 9 of 13
(7,417 Views)
So I solved it so, that I use browser SlimJet in version  30.0.5.0 and I fixed this version (disallow updates). It works 🙂
Message 10 of 13
(7,412 Views)
