NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
关于数字显示问题
呵呵,不要叫我鬼哥哦,我也是女生,17岁,比杨还小1岁,哈哈,开玩笑。我还是学生。LV很有前途的,现在最流行的就是搞嵌入式和虚拟仪器,还是建议你不要放弃。我和杨都对这个行业很有兴趣。
Lady And Basketball Vividly In my Exciting World !!!
Daniel.Tang E-mail: tangye@friendess.com
0 项奖励
41 条消息(共 87 条)
6,179 次查看
事到如今,我也只好公开我的身份了难过表情
其实我也是女生,怕大家瞧不起女生,所以才取了个BOY的名字.
TO Yukee:
客户很满意,周2就现场试机了.谢谢你大力支持我.
党教育我们要忠于人民
0 项奖励
42 条消息(共 87 条)
6,171 次查看
是不是大家最近超级女生看多了啊,极度高兴的表情
0 项奖励
43 条消息(共 87 条)
6,169 次查看
Tang is my younger sister ! I see her growing up ! she is archness and lovely.
Now. She is looking for a boyfriend, but he must know labVIEW about. who would like to take on this role ? ^.^ thanks @!
________________________________________________________
Try to make everything Automatic
0 项奖励
44 条消息(共 87 条)
6,164 次查看
faint~~~~~~~~100 times
0 项奖励
45 条消息(共 87 条)
6,163 次查看
Yukee:
archness是什么意思 ?
党教育我们要忠于人民
0 项奖励
46 条消息(共 87 条)
6,157 次查看
Yukee,糖糖(好lovely哦吐舌表情
帮我看看为什么加了个事件结构之后程序就有问题了。
我是想用鼠标选中string,焦点就跳到该string上
党教育我们要忠于人民
0 项奖励
47 条消息(共 87 条)
6,157 次查看
Proven Enthusiastic Veteran tst told us :
You should not have multiple event structures in the same loop and inside cases. That's just a recipe for having your FP become locked and unresponsive and for all sorts of weird things.
Let's assume you want the code in the value change to execute only when the tab is in that page and only when that specific radio button was selected. In that case, what you should do is reverse the order - the event structure should be on the outside and the case structures should be inside the event structure. If the radio button can't change if the tab page isn't shown, you don't even need the case checking for the tab page.
Once you did this, you can simply add a value change event for the stop button and wire T out of that case into the stop terminal. Once you press the button, that event will execute and the loop will stop.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
The style guide and chapter 17 of the manual should cover more about events.
0 项奖励
48 条消息(共 87 条)
6,145 次查看
yukee & gui,方便的话,可以说一下你们的qq号么?
我用Lv做测控系统一年多了,但对于Lv目前的应用状况以及将来的前景有一些迷茫.
而且目前还没确定自己将来的发展方向是否就按照现在虚拟仪器方向走.
所以想跟两位交流一下,或者我们可以建一个qq群?谢谢.
0 项奖励
49 条消息(共 87 条)
6,135 次查看
Sorry I use qq only chat with my friend about untechnical topic. You can see my Email address as follows. If you have problem with regard to LV you can send mail to me. However, it's better to ask questions here, 'cause there are a lot of master-hand here. I dare not to say I am as good as them. Thanks and regards.
0 项奖励
50 条消息(共 87 条)
6,133 次查看
