NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
关于数字显示问题
还能不能再帮我加个扭,退出整个程序的控制
党教育我们要忠于人民
0 项奖励
71 条消息(共 87 条)
5,016 次查看
cause your application of action is waiting for the other handle case completed !
attached is you need
________________________________________________________
Try to make everything Automatic
72 条消息(共 87 条)
5,014 次查看
我点下确定结束的那一瞬间留下了鼻血,
居然整个退出了LV。我开着好多程序呢。。。。。
还好这个俺会改。。
党教育我们要忠于人民
0 项奖励
73 条消息(共 87 条)
5,013 次查看
it is you told me that 还能不能再帮我加个扭,退出整个程序的控制
he he
0 项奖励
74 条消息(共 87 条)
5,012 次查看
再问下你,这样用到事件结构的程序能做成子函数吗?
做成子函数,输入string的名字不一样,事件结构还能触发吗?
党教育我们要忠于人民
0 项奖励
75 条消息(共 87 条)
5,011 次查看
Yes you can.
create string or number controls how many you set, make them as Subvi's input node.
it doesn't matter what the string's name or number name's target connect it !
0 项奖励
76 条消息(共 87 条)
5,010 次查看
then .that subvi have no output?
buttons also as input?
党教育我们要忠于人民
0 项奖励
77 条消息(共 87 条)
5,009 次查看
No. need input and output.
I suggest you that don't align it as a SubVI, it will be confuse for you !
0 项奖励
78 条消息(共 87 条)
5,007 次查看
would this stop fuction be better?
Lady And Basketball Vividly In my Exciting World !!!
Daniel.Tang E-mail: tangye@friendess.com
0 项奖励
79 条消息(共 87 条)
4,995 次查看
BoyKK,
   Sorry,
   The SubVI which you told with me that cann't be made. cause the event occurs "mouse down event". it is focal to the solid string control, waiting for mouse down event occuring.
0 项奖励
80 条消息(共 87 条)
4,991 次查看
