NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
去除字符串后的空格
已解决!
转到解答
有谁知道去除字符串后的空格
"adc dbd ghg          "
变成
"adc dbd ghg"
0 项奖励
1 条消息(共 7 条)
6,479 次查看
Do you have the Trim Whitespace.vi under String functions palette?
Message Edited by ian fung on 01-22-2010 03:11 PM
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 7 条)
6,476 次查看
i am using the CVI, can you tell me a function in CVI ?
0 项奖励
3 条消息(共 7 条)
6,424 次查看
I see... you should have mentioned that... some CVI experts might be able to give you the answer then... hope you will solve it soon 🙂
Ian F
依恩与LabVIEW
0 项奖励
4 条消息(共 7 条)
6,421 次查看
解答
接受人 Gerryli
void RemoveSurroundingWhiteSpace (char string[]);
Message Edited by ian fung on 01-25-2010 11:08 AM
Ian F
依恩与LabVIEW
5 条消息(共 7 条)
6,416 次查看
ian fung 写:
Hi, Sir
 thanks for you helps, i have tested this command, it is really i want.  en. looks you are also CVI expert  🙂
0 项奖励
6 条消息(共 7 条)
6,412 次查看
并不是因为我知道, 而是因为我努力查找 😉
PS: 虽然开始时有接触过CVI, 但因不太喜欢Text-based 编程, 所以自一九九九年都以LabVIEW为主...
Ian F
依恩与LabVIEW
0 项奖励
7 条消息(共 7 条)
6,403 次查看
