NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
怎样在FPGA项目中对C9401(八通道数字IO)编程生成一个脉冲?
刚接触,对FPGA编程不太了解,望高手指点谢谢
0 项奖励
1 条消息(共 3 条)
3,423 次查看
I think you could start from a simple FPGA project, try to find a simple example in Example Finder after you have installed the Labview FPGA Module, understand how to manipulate I/O node and timing config, then you may have an idea about your application.
0 项奖励
2 条消息(共 3 条)
3,398 次查看
thank u
0 项奖励
3 条消息(共 3 条)
3,358 次查看
