Dear Customer,
You can't set which part the FrontPanel of the VI called in SubPanel.
However, you may resize the FP of the VI called to the position and size you want, than choose File->VI properties->Window Size->Set to Current Window Size, than Edit->Make Current Values Default. The prefered position will be show rather than the default.
-John
Yes, I think there are both good queries and answers issue.
for Dynamic custom FP location. you can use VI properties node ,window bounds and origin. but the handle needs your shape.
