NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
请问,DAQmx的函数是如何处理信号干扰的?
项目用到PXI-5122数字化仪和PXI-6224DAQ。
假设采集的信号有干扰,例如测量峰值时,NI的板卡能够消除这样的干扰吗?或者说,类似Waveform min max.vi这样的测量vi是怎样处理干扰信号的?会不会得到的峰值是干扰信号的?谢谢
Windows XP SP2+LabVIEW 7.1
0 项奖励
1 条消息(共 2 条)
3,233 次查看
Dear Customer,
For NI-DAQ, the acquisition VIs will not filter out the noise automatically, so as to NI-Scope.
However, you may add software filters (i.e. High pass or Low pass) in LabVIEW, then process analyzing VIs like Waveform(Min/Max) etc., and you will get the expected readings (i.e. Peak Voltage).
-John
John L.
0 项奖励
2 条消息(共 2 条)
3,222 次查看
