但是运行程序后总是提示错误,错误代码是:ERR1059,其错误源在Open VI Reference in NI_ReportGenerationCore.lvlib:ChangePathToVIRefCallerDefault.vi->NI_ReportGenerationCore.lvlib:Append Front Panel Image to Report (path).vi->report output.vi<APPEND>
VI Path: <b>D:\WORK\8.NI\091202\3333.jpg</b>
实在是不明白怎么回事,希望能帮忙解决,非常感谢!!
已解决! 转到解答。
Thanks for your answer, and I change the VI. replace previous bloack diagrom follow as:
But when I run this block , the result is OK but the output path I can't control, and I don't know where the generate report. So I can't find the report file. Could you like give me some advice? I want to get the correct file path.
Thanks for your attention, please!
Thanks! I had edit new diagram like this:
and this program can work, the output only contain the image that I want to insert into my report, but don't contain my previous template mode example *.word *.xls. So the final report only image display , it isn't I want report format.
I would be very appreciated If you can help me!
Please try searching report examples from the examples finder in LabVIEW.
There are good examples for both text or html reports.
There are many useful functions under the report generation palette, please go through them.
Since you have selected/ highlighted your own reply as Solution, would you mind telling me if my replies of helpful or answering to your problems? Do they worth a Kudos?
This will help to tell other which is the overcoming solution to your problem 😉
Thanks!
