As I know, stepper motor driver running condition needs enable, direction and pulse etc signals. some needs reset one.
if the hardware can generate upwards signals, that your motor can be control and working !
if you want to get a precise of moving station's running result. and the motor has encoder about. the card need a read encoder function!
________________________________________________________
Try to make everything Automatic
