NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
无法打开LABVIEW7.1提示错误是The feature"localhost" has expired
如何解决,请赐教.本人用的LABVIEW7.1是正版的,而且是永久激活的,前些天使用正常,但现在却出现The feature"localhost" has expired,打不开软件了.
0 项奖励
1 条消息(共 4 条)
4,926 次查看
It's probably way out of date topic, but in case someone else have similar issue, here's the possible solution :
go to c:\Program Files\National Instruments\Shared\License Manager\Licenses\
If you have genunie LabVIEW you should have file "LabVIEW_LabVIEW_070100.lic".
Now. There might be also file called "LabVIEW_LabVIEW_070100_TmpEthernet. Remove it, and then try restarting your LabVIEW. This should solve the "The feature 'localhost' has expired" issue.
0 项奖励
2 条消息(共 4 条)
4,492 次查看
duoke你好,
你是否更改了电脑的配置,特别是NI许可证相关文件?建议重装LabVIEW 7.1,或进行LabVIEW升级。
"spawn more overlords" means "create another subVI, dude", literally
0 项奖励
3 条消息(共 4 条)
4,476 次查看
The original post was writtten in 2008, so he probably doesn't have this problem anymore.
0 项奖励
4 条消息(共 4 条)
4,469 次查看
