NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
求救~!!急~!!
工程师:
怎么样设定子VI里面的返回按扭,让它返回到前面的VI.我设定了,怎么样都不好使.
0 项奖励
1 条消息(共 3 条)
4,844 次查看
需要用到参考及对应功能或属性节点
0 项奖励
2 条消息(共 3 条)
3,708 次查看
If you are calling sub-VI from the main VI (the caller), once the sub-VI is terminated and closed, it should goes back to the main-VI (the caller).
PS: please check that you have set, at least, the following in the VI Properties:
  • Show front panel when called
  • Close afterwards if originally closed
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
3 条消息(共 3 条)
3,705 次查看
