我尝试过,没有用
而且其他正常的VI文件也同样不能生成安装包了
都是显示那个错误报告,唯一的区别是生成路径的区别
例:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_BuildDevPart.vi >> NI_MDF.lvlib:MDFBuildDevPart_Open.vi
Loading product deployment information
Adding files to installer
*** Error: Windows SDK function returned an error. (Error code -12)
Error accessing build path "E:\PSM\PSM2\19V\Builds\19V Power Supply\My Installer\temp\dp\".
Could not copy file (source = "D:\Program Files\National Instruments\Shared\MDF\Bin\DKTemplate0009.msi"; destination = "E:\PSM\PSM2\19V\Builds\19V Power Supply\My Installer\temp\dp\devpart.msi").
Access is denied.
*** End Error Report
Error accessing build path "E:\PSM\PSM2\Builds\Power Supply Multimeter\My Installer\temp\dp\".
Could not copy file (source = "D:\Program Files\National Instruments\Shared\MDF\Bin\DKTemplate0009.msi"; destination = "E:\PSM\PSM2\Builds\Power Supply Multimeter\My Installer\temp\dp\devpart.msi").
Access is denied.
