NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
A game issued, if you are interesting that you can view it
this is a simple game that shot my mind a day. and I issued it.  that is little interested. you can try it. Yes, labVIEW analyses data is stronger.
________________________________________________________
Try to make everything Automatic
0 项奖励
1 条消息(共 15 条)
8,693 次查看
呵呵,我看了你做的东西,觉得好好啊!
但是怎么看不到流程图啊。
少壮不努力,老大徒伤悲
0 项奖励
2 条消息(共 15 条)
8,677 次查看
Yukee是用picture来做的嘛?
0 项奖励
3 条消息(共 15 条)
8,672 次查看
Yes. this mind is through a game which is "Jie ji" , do you like it ? I play "jie ji" usually. I think my mind is as the same as some "Jie ji" software issued (principle)
0 项奖励
4 条消息(共 15 条)
8,669 次查看
做游戏是很提高对Labview的使用技巧的
但是我目前的感受是:Labview的主要目的还是在
和Ni的硬件来使用,它不是一个通用的编程工具
然后数据采集的问题无限多
0 项奖励
5 条消息(共 15 条)
8,667 次查看
I think that LV can support some hardware which is not NI's, namely ,not all of test station needs NI's hardware products that can achieve only .
for example, series hardwer.TCP/IP or UDP communication technology ...and we ssue some hardware which can generate High frequency signal, control servo and stepper motor,and some sensors. and this hardware are design by us.
we issue the hardware driver with C langue. but we use LV control our hardware to take the action responding. test our station's every parameters. LV is very good. and we call our system that is High performance motion controller.
0 项奖励
6 条消息(共 15 条)
8,666 次查看
在ni的角度上看,它要努力做好一个系统
第三方产品对ni来说不是正式支持的,它提供dll的节点
你可以用,但是ni努力开发更简单好用的模式
从daq助手和MAX都可以看出来
Ni的产品价格不菲,但是它的优点是对底端程序屏蔽
对于用户来说,用ni板卡开发时间会少很多
像Yukee一样做板卡的来说,用什么平台都是没有区别的
当然Lv更好用更简单,用户更注重的开发简单,能用就ok了
0 项奖励
7 条消息(共 15 条)
8,663 次查看
Yes, I gree your mentioning.
LV+ NI hardware products would save your development's time much much . but we know NI's hardware products are little expensive. if you want to do a simple action or need a simple signal only, not high performance one. that you can think about ,whether purchase a hardware or make a hardware by yourself. just compare.
0 项奖励
8 条消息(共 15 条)
8,659 次查看
Yes, I agree your mentioning.
0 项奖励
9 条消息(共 15 条)
8,657 次查看
0 项奖励
10 条消息(共 15 条)
8,507 次查看
