NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
A game issued, if you are interesting that you can view it
对于测试来说,精度和速度是第一位的
0 项奖励
11 条消息(共 15 条)
3,557 次查看
cost is the first.
As you design a product, you must calculate your product's cost compactly. if a simple module can achieve the same function. I will choose the simple module. certainly. please don't drop your product's quality .Yes  ^.^
this is a company's development planning.
________________________________________________________
Try to make everything Automatic
0 项奖励
12 条消息(共 15 条)
3,408 次查看
测试一般是为了验证产品设计或者生产产品后而做的
成本是一次性投入,可以分摊到每个测试的产品上
就研发而言,测试成本本来就是很高的
0 项奖励
13 条消息(共 15 条)
3,406 次查看
He he,
I don't think that LV made test station only.
at my past many years ,I have issued many station are not for test station. For example, "Random select question paper system" "SQL server 2000 process data system (use TCP communicates data) which LV sends command to SCM, and SCM sends data to LV, and LV saves it to SQL etc.
  and we are controlling many many instruments about. some instrument has its series port, RS232 and IEE-488, what would you do ? yes ,you can use GPIB card to achieve the data getting.and it is fast. but we won't, we are using RS232 usually instead. the result is all the same and content our demand. this channel handle tells that save money only, he he.
0 项奖励
14 条消息(共 15 条)
3,404 次查看
看问题的角度不一样嘛
0 项奖励
15 条消息(共 15 条)
3,398 次查看
