NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
About DAQ Assistant,Advanced Clock Setting
In DAQ Assistant,Advanced Clock Setting, what is meaning of Internal and external clock type?what is differrence between them?
Thank you!
0 项奖励
1 条消息(共 2 条)
3,489 次查看
There is a crystal oscillator on board. It can provider sample clock to Analog input, which is called internal clock. At the same time NI DAQ board can use external clock from PFI pins or other sources.
帖子被Richard.Xu在10-25-2005 06:34 AM时编辑过了
0 项奖励
2 条消息(共 2 条)
3,481 次查看
