NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
CVI Warning: CVI Debugger was unable to obtain permission to run watchpoints
已解决!
转到解答
Bonjour ,
En voulant exécuter mon application en mode Débug un message de warning s'affiche accompagné d'une fatal error:
CVI Warning: CVI Debugger was unable to obtain permission to run watchpoints. You might not be able to use watchpoints during this debugging session.
Bien que en mode release il n'ya pas de problème et que l'application fonctionnait en mode debug , la session que j'ai utilisé son administrateur & utilisateur normal même constat
 Merci
When trying to run my software in debug mode a warning appears accompagned with a fatal error:
In release Mode : no pb
The debug mode could be used
I am using an administrator session in PC
0 项奖励
1 条消息(共 3 条)
4,486 次查看
解答
接受人 vin_sagem
Hi vin_sagem,
Thank you for using NI Discussion Forum! For your case, you may want to exclude cvistart.lib in your project. Let me know if there is still problem.
NISH AE
W. Yan
"spawn more overlords" means "create another subVI, dude", literally
0 项奖励
2 条消息(共 3 条)
4,465 次查看
Thank you !! it works again , problem solved by exluding cvistart.lib
0 项奖励
3 条消息(共 3 条)
4,447 次查看
