NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
LABVIEW常量赋值问题
想要在程序中定义一个常量作为比例系数K,在运行过程中根据计算结果对K进行重新赋值。
简单来说 就是如何实现如下代码:
UINT16 K=0  ;  //比例系数
result_celiang=0;// 实际测量值
result_lixiang=5;// 理想值,理论值
int main()
      /                //得到实际测量值
  result_celiang=4.986;  //得到实际测量值
  K=result_lixiang/result_celiang;//利用测量值和理想值修正K的(每测量十次修正一次)
0 项奖励
1 条消息(共 2 条)
3,970 次查看
Suppose that you have created an numeric indicator i.e. K of UINT16.
At code initialization, input 0 to K.
During main code execution...
At when new K value is to be updated, simply write that computed value to K's local variable.
In other word, upon initialized the K value before the main code, simply "right-click" K and create a local variable of it. Then, update new K's value with this local variable.
PS: Global Variable could also be used in this case.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 2 条)
3,945 次查看
